co-tron components limited
partex marking systems
Ready marked single character sleeves that can be combined to produce the completed legend. The installer assembles the combinations required, on site, using markers specifically designed to meet every application. A wide range of packaging types and accessories are available to simplify the marking process.
  • The PY Wire Marker
    In response to customers requests for a marker to identify the increasing number of smaller diameter data, fibre-optic and telecommunication wires Partex introduced the PY marker
  • The PA Wire Marker
    The original, and best selling, Partex marker.
  • The PZ Straight Cut Wire Marker
    The PZ series is a straight cut version of the best selling PA marker, available, ex-stock, in the most popular sizes and several different packaging styles including, our new reusable plastic boxes.
  • The PAZ Wire Marker
    Single character, chevron cut markers made from Zerex - a thermoplastic based polyurethane mixture that is free from halogen, cadmium and silicon.
  • MDH Refillable Key Ring Dispenser
    The MDH10 installation tool and MDH20E holder form a complete installation package for on site work with PA sleeves.
  • CAS Refillable 'Pocket Size' Cassette Dispenser
    Cassette Dispenser for either PA1 or PA02 cable markers. Includes an appropriate PUJ installation tool.
  • PAL 18 Compartment Marker Box
    Assortment box which facilitates combination marking work at installation site. Available containing PA1, PA02 and PY markers.
  • Applicators for Closed Ferrule Markers
    Nylon and Teflon coated stainless steel applicators for quick and easy installation of Partex markers.
  • Applicators for PC Open Wire Markers
    The PG applicators make it easy to mount PC 'open style' wire markers, even where access is difficult.
  • PLD Self-Adhesive Markers
    Refillable key ring dispenser containing 10 rolls of self-adhesive single character markers.
  • PC Single Digit 'Open Style' Wire Markers
    An open marker sleeve design for post termination marking. Suitable for electrical, pneumatic and hydraulic applications.
  • PCA Single Digit 'Open Style' Wire Markers
    A clip around wire marker for post termination marking. Facilitates easy marking of connected cables, rapidly installed without tools.
  • PS Control Panel Marking System
    A universal marking system for control panels and components.
  • POK Cable Markers and the POH and PKH Carrier Strips
    The largest of the Partex range of cable markers, suitable for cable diameters up to 7mm. For larger diameters the POK10 marker is used in conjunction with the POH or PKH carrier strips.
  • POZ Cable Markers and the PKH-POL Carrier Strips
    A halogen-free version of our POK10 cable markers, suitable for cable diameters up to 7mm. For larger diameters the POZ10 marker is used in conjunction with the halogen free PKH-POL carrier strips.
  • PKS Stainless Steel Cable Markers
    A complete marking system for cables, hoses, pipes and components in hostile environments.
